Home › Forums › Club Races › Racing Calendar, Classes & Regulations › 2023 – Ford vs Ferrari
- This topic has 12 replies, 6 voices, and was last updated 3 years, 3 months ago by
Jay.
November 9, 2022 at 9:40 AM #18406
All – The rules for the H1 Ford vs Ferrari series are attached to this post. Please review and reply with any comments.
It would also be nice if you could list the car you are planning to run so we limit the duplicate liveries. Thanks!
November 9, 2022 at 5:55 PM #18415Alan Mann 24 GT40 (Sebring)
November 9, 2022 at 8:53 PM #18416I’d like to run the 412p #11/Mairesse & Beurlys. Spa 1967
Two questions.
About tires, I have the stock fronts on currently which are 9.3mm wide. Are they not legal?
About guide: Is it legal to alter the shape of the guide (rounding sharp corners, etc.)?
Thanks!
"Enjoy every sandwich"
-Warren ZevonNovember 9, 2022 at 10:25 PM #18417Who is the manager for this race
November 10, 2022 at 8:31 AM #18418David – John is the race manager.
Datto – the stock front tires are legal, they are considered 10mm.
Datto – Yes, you can shape the guide. Rounding the corners or putting a finer point on the front, sanding down the sharp edges, sanding the rear of the guide so it does not catch on the chassis – all legal just as long as you are using a Slot.it guide.
November 11, 2022 at 3:49 PM #18427Which Ferraris are legal. All of them?
November 13, 2022 at 2:27 PM #18431All Policar Ferrari 412P’s are legal. See the chart below for the four models.
Note – it’s my understanding that only the CAR06c comes with the aluminum rear wheels under the base in the packaging. Let me know if there are more models that come with the spare aluminum wheels.
November 13, 2022 at 2:35 PM #18432I hope to be running the NART Ferrari P412 #25 from the 1967 Le Mans with Pedro Rodriguez and Giancarlo Baghetti at the wheel.
November 13, 2022 at 2:48 PM #18434More information about using NSR tires on Slot.it/Policar wheels
I noticed that NSR produces a special rear tire to work on Slot.it wheels – #5262Black. Once I noticed they produced a unique tire for Slot.it wheels I looked a little deeper at the differences between NSR and Slot.it wheels and discovered there is a 0.10mm difference between the center rib on the wheels. All Slot.it wheels use a center rib that is 5.1mm wide while all the NSR wheels use a center rib that is 5.0mm wide.
Discovering this I thought there would be an issue in using NSR tires on Slot.it wheels. Then I measured the NSR tires and discovered that the center rib on the tires measures anywhere from 5.1mm to 5.25mm so I don’t think mounting NSR tires to Slot.it wheels will be an issue.
Having said that, I would definitely make sure the tires were properly glued to the wheels. At 12 volts you don’t want the tires coming off of the wheels.
November 20, 2022 at 10:57 AM #18482I really want to run whatever is under that red cover.
Baring that, I’ll be running this beauty:
(Leroy Grumman)January 4, 2023 at 11:06 AM #18601Holy cow! I don’t know if any of you running this series have checked the RPM on your motors but both of my motors were very “hot”. I have one that has an RPM of 26.6K and another at 25.8K at 12 volts. These are supposed to be the standard Slot.it 23K motors. This may require me to gear down from the stock gearing or add a significant amount of weight. Running one of these “hot” motors and the stock gearing the projected wheel RPM is 9,144. That is super quick for a very light 58.5 gram car. As they say in the Pirelli ad “Power is nothing without control”.
You have been warned.
January 4, 2023 at 5:50 PM #18603I finally got my GT40 together and ran laps this afternoon. Pretty stable with one tungsten weight.
January 5, 2023 at 10:32 AM #18604 -
