Home › Forums › Club Races › Racing Calendar, Classes & Regulations › 2017 Series Talk
- This topic has 32 replies, 6 voices, and was last updated 8 years, 11 months ago by
Butch.
October 30, 2016 at 6:00 PM #9809
Per ASCC Ad-Hoc Club Meeting Oct 29
917-2017 Series
Specs: NSR, any current or recent 917 model.
Mods: NSR 22k Shark motor, NSR screw guide, black chassis with adjustable front axle height, NSR No-Grip front tires, NSR gears can be changed, smooth shank body screws, rear wheels can can a solid nib/rib or be AirSystem
OEM Required parts: Body, hard cabin/tub, wire, medium/black chassis, stock rear tires (can be trued)- After a discussion regarding chassis – we voted to spec the stock medium black chassis; therefore leveling the specs and helping to reduce additional expenses. If a racer has an old black chassis w/o adjustable front axle pillars, they can upgrade ($9) to a current medium/black chassis.
Not Allowed: Grinding of body or chassis, independent rotating front wheels.
Numbers, type, livery must be chosen. Please make your pick before Nov 12
Current dibs: Dave #14-GES IPA, Ary #7-Gulf, Mark #2-Gulf, Russ #20-Gulf, Marty #23, Alex Whitekit, Randy #13, John B #1-Gulf, Rich #3Goodwood-2017 Series
Racers will have to declare your car to prevent duplicates. Fantasy liveries are allowed to help differentiate between duplicate or similar OEM liveries.
The Racer Silver series is allowed.
No metal chassis are allowed, Slot.It HRS-2 and similar plastic adjustable chassis allowed."... get on your bad motor scooter and ride!"
Sammy with MontroseNovember 2, 2016 at 2:37 AM #9826List of 917s NSRs available at Electric Dreams
Sammy with MontroseNovember 2, 2016 at 5:51 PM #9828NSR 917 Parts List
BODY
Interior Parts Kit: (no body shell) #1342
Lights and glass #1341
Complete kit with Shell #1349Medium/Black Chassis:#1339
Medium/Black Pod: #1247
Height adjusting screw kit: #1238
SCC 4-40 Oval Point Set ScrewsScrew Guide: #4844
Guide Post Screw: #4852
Wire: (.75mm) #4826, (.25mm) #4824MOTOR
Shark-22: #3001F (with sidewinder pinion for end-bell drive)
Pinion: (6.8mm SW) #6910, #6911, #6912, #6913
Spur: (17.5mm SW) #6030, #6031, #6032, #6033, #6034, #6035, #6036, #6037WHEELS
Front -or- Rear (solid rib) (16×8) #5001
Rear (air system channeled rib) (16×8) #5002
Rear (air system channeled rib) (17×10) #5004TIRES
Front: No-Grip for 16mm wheel: installed size 17×8 #5201
Rear “classic” (treaded) SuperGrips for 16mm wheel
Installed size 18×10 #5239
Installed size 20×8.5 #5234
Installed size 20.5×10 #5253"... get on your bad motor scooter and ride!"
Sammy with MontroseNovember 3, 2016 at 9:18 AM #9830For those that don’t know already, the car comes with a 11t pinion and 32t spur from NSR.
Here is a link to all the stock parts and part #’s for the 917K:
November 3, 2016 at 11:37 AM #9832Shawn I have some questions:
— I believe the red-hard pod is OEM; so I assume that’s the spec part.
— Are no-grips allowed; if so do they have to be the treaded no-grips (aka Classic) and is that the NSR #5201, or are the slick NSR no-grips allowed
— So we can get spares for the rear, is the spec the Supergrip Treaded or Slicks? (in last weeks adhoc meeting Ary suggested the OEM style, treaded.)
— Is the NSR screw guide allowed (vs the OEM snap in model)
— Are we allowing the spur to be changed (as with most series)?
— Are ball-bearing or swivel (Victors) bushings allowed vs the OEM oilites?
— Do wires have to be the OEM skinny cable?
Sammy with MontroseNovember 3, 2016 at 2:01 PM #9833Mark,
Since I was camping with Alex for scouts when the rules were finalized, I can’t fully answer your questions. Historically, we’ve not allowed the low profile front tires due to the non-scale appearance. I expect that to continue which would eliminate the 17×8 zero grip NSR tires. All of my NSR 917Ks have the black motor pod so I’m not sure that the red is the stock spec. If anyone has a newer 917, perhaps they can help us out. According to the post you made on Monday, gears are open. Somewhere I remember seeing that we’re allowing the NSR screw in guide. Since people were wanting to keep the costs low, I would say the stock oilite bearings to be retained. This whole keeping costs down on a NSR series is still baffling to me but whatever. The rear tires are to be the stock tires but can be trued which eliminates the “tread” on them. Again this is from your post on Monday.
I’m confused why you’re asking me about the finer details on the rules as that didn’t seem to stop everyone from making those changes to the rules without my input.
November 7, 2016 at 7:53 AM #9836Shawn,
— The text part list I posted was taken from the HTML table from the NSR site (the HTML is hard to read)
— At the meeting 10/29 several suggestions were made. I was not aware of which ones may have been from someone reflecting a discussion they had with you. Since you are the Race Manager, like other series the rules are yours to finish. The only topic we really voted on was the hardness of the chassis.
My question on no-grips was about allowing any NSR no-grips (since we do allow no-grips in some series).
As race manager you may want to finalize rules (by declaration or by vote) this Sat 11/12.
Sammy with MontroseNovember 7, 2016 at 8:00 AM #9838Since the series was changed from Fly 917K to NSR 917K, I’d say quite a bit more was decided than just the chassis stiffness.
November 7, 2016 at 8:24 AM #9841"... get on your bad motor scooter and ride!"
Sammy with MontroseNovember 7, 2016 at 8:56 AM #9842Mark,
Ary has dibs on the Gulf #7 1970 Monza not me. I have the #24 Salzburg from 1970 LeMans.
November 28, 2016 at 11:12 AM #9883I will update the list. Looking forward to the final rules – moreso to the race!
Sammy with MontroseDecember 3, 2016 at 6:04 PM #9889GoodWood – Tourist Series
Is the Fly GT250 raced in Targa Floria legal?"... get on your bad motor scooter and ride!"
Sammy with MontroseDecember 7, 2016 at 12:37 AM #9897GoodWood – Tourist Series
I plan to enter a Monogram Cobra, and Fly FT250 as backup (both HRS-2 chassis)
Sammy with MontroseDecember 15, 2016 at 7:55 AM #9925December 17, 2016 at 12:45 PM #9943917 DIBS needs updating.
Sorry guys something got fubared on the list.
- Russel = #20 Gulf (not on list since its an older model)
- Rich – #3 Piper
I will post as a table
PLEASE SEND ME ANY UPDATES
