Home › Forums › Slot Car Talk › Tech Tips / Q & A / Tutorials › Modifying a RC comm lathe to use with slot armatures › Slot.it Challenge Q1 – Round 1 Results
- This topic has 3 replies, 3 voices, and was last updated 15 years, 2 months ago by
Bellator.
January 16, 2011 at 7:15 PM #154
The results are in. Our intrepid ASCC racers braved the cold and wet to turn in the results attached.
Leaderboard as of Round 1, January 15, 2011.
Position/Driver/TotalLaps/Points
1 / Ary B. / 216 / 11 **+1 point awarded for fastest race lap
2 / Shawn G. / 206 / 8
3 / Marty M. / 206 / 6
4 / Brian H. / 192 / 5
5 / Russell M. / 190 / 4
6 / Roy M. / 189 / 3
7 / Jim J. / 165 / 2Attachments:
(Leroy Grumman)January 17, 2011 at 4:10 PM #1051Wow! Marty, you have no reason to belly ache about your motor. 😛
January 17, 2011 at 9:47 PM #1052I don’t know if I was belly aching as much as I was complaining about Ary de-slotting and causing me to loose my concentration and crash. That was my major concern.
Having never prepped a new motor for a series I was not happy with the initial low RPM of the motor but knew on Thursday night it was running better. Thursday evening I recorded 17,600 at 10.20v and could feel the car getting faster as the night went on.
January 26, 2011 at 10:03 PM #1053Guys,
The “steward” (me) has just finished a detailed review of the previously reported Round 1 stats and confirmed that a bug in the software has caused the fastest laps to be reported incorrectly. Scoring was done properly in the RMS, (the fastest lap was awarded to the correct driver) but reported incorrectly by me because I used the Statistics display to compute them by hand.I have reported the bug to the author of the software who has confirmed it and promised a fix. The following link will take you to the bug report if you are interested: https://pclapcounter.winnerbb.net/t800-fastest-lap-issue-when-running-heats#3528
Here is a short explanation of the issue: When running in the race configuration that we have selected (we don’t complete laps at the end of a heat) the software is supposed to ignore the lap time of the first lap of the driver’s next heat when evaluating fastest laps. The reason for this is that when the power is cut to the track at the end of a heat and timing is paused, our cars keep coasting. Based on our average lap times we were averaging distances traveled from 10.4 to 15.66 inches per 1/10th of a second. If a racer is lucky enough to have the power cut on one of the straights where they are at or near full speed they could easily travel enough distance to trim over 2/10’s of a second off their lap time.
I have not adjusted the scoring in the RMS, as it is correct. I have simply posted the report from the RMS in place of the original file. I have also updated the summary files because they contained incorrect fastest laps for many of us.
My most sincere apology for making this error.
BrianBuild it strong.
(Leroy Grumman) -
