Reference material for new members
Home Forums Slot Car Talk Tech Tips / Q & A / Tutorials Reference material for new members
Viewing 10 posts - 1 through 10 (of 10 total)
  • #561
    Avatar photoAutorama
      Slot.it 2013 Spare Parts Catalog: Slot_it_Spares_2013.pdf
      Gear Ratio table (Slot Car Corner): Slot.it Gear Ratio Chart
      Adjusting the front axle height on Slot.it models (Slot.it): Front Axle Setup
      The fine art of straightening a slot car chassis (Slot.it): Art Of Chassis Setup
      #1679
        At this point I have finished 3 of 7 (maybe 8) videos showing how to setup a Slot.it car for our track. All the videos will be available at the club’s YouTube channel: https://www.youtube.com/user/AustinSlotCarClub.
        Here are the first 3 parts:
        Pt #1:
        Pt #2:
        Pt #3:
        #1682
          Video #4 – Gear selection:
          #1684
            Avatar photoporsche917
              Lets say I am setting up a car and the motor RPM is 21,4k and the gearing is 9×23.  If I did the math correctly, the wheel RPM should be 8,374.  Lets say I have this set up and I am only getting 7,960 RPM at the wheel.  I have checked to see if there is any binding of the axle in the bushings as well as gear mesh and it all looks good.  Why would I see such a difference from the calculated RPM and the actual RPM?
              I have used this formula before and it has always been close but this one is way off the projection.  Thoughts oh great gear set up master?
              #1690
                When the motor is warm, it revs higher. Do you think you checked motor RPM while the motor was warm and wheel RPM with a cold motor?
                If no, I would test motor RPM again and check to see if it dropped from the original 21.4K.
                If no, you probably have a motor with very little torque.
                #1691
                Avatar photoMitleid
                  Thank You these videos have been a great help to me
                  #1693
                    One to go.
                    #1694
                      Vid#7 updated …
                      #1695
                      Avatar photoBellator
                        Great stuff Ary.
                        Thanks again for putting the time into creating these how-to videos.
                              (Leroy Grumman)
