Home › Forums › Slot Car Talk › 1/32 Scale Slot Cars › Professor Motor Deep Wood Guide
- This topic has 4 replies, 3 voices, and was last updated 11 years, 6 months ago by
September 15, 2014 at 1:26 PM #6049
I have found this guide to be a great alternative to Slot.it wood guides. The shaft is longer than most and needs trimming for a custom-fit. It also needs a light sanding to fit into a slot.it guide hole (or an adapter) b/c it is intentionally thicker to provide a snug fit (that get perfect after about an hours track time).
It uses the same grub-screw design as the slot.its. It is ever so slightly deeper than the slot.it wood guide. It also has bumps on each end so that it has the effect of a thicker guide without the additional mass.
https://www.professormotor.com/product-p/pmtr1147.htm
Professor Motor PMTR1147 1/32 Universal DEEP WOOD Guide
Sammy with MontroseSeptember 15, 2014 at 11:18 PM #6077Nice tip! I will make sure t order a few next time I order from Professor Motor.
September 19, 2014 at 11:03 PM #6105Is that the same guide David got and had trouble with them being brittle
September 22, 2014 at 4:58 AM #6110Is that the same guide David got and had trouble with them being brittle
I don’t know. Can you verify?
September 26, 2014 at 11:07 AM #6188Sept 26 – I talked with David last night and he verified that he and Jordan had the stem break. It was obviously too flexy/brittle (before installation it could be bent too easy with moderate finger pressure).
BUT – he contacted Professor Motor and they acknowledged it was a bad batch of guides. David said this was several months ago (early in the year?)
I have been using these guides, on two cars, for a few months and they have not had any problems.
Of course, the Slot.It wood guides are great and usually available at Kings. The most advantages the ProfesorMotor guides have are (a) a stem that can be customized to allow any height (e.g. when you need to add a few shims to get the guide deeper), and (b) a fit that can be customized (e.g. when you have a worn guide-boss or otherwise sloppy guide. Again, my experience has been that they are an alternative to the Slot.It guides JIC someone wants to try something new or cannot get a Slot.It deep-wood guide.
