Offset Crown Gears
Home Forums Slot Car Talk 1/32 Scale Slot Cars Offset Crown Gears
  • #607
      A couple of questions on these..
      My McLaren came with a white crown gear with only a number “2′ embossed . How do you determine the number of teeth on these gears short of having to count them?
      Also, are there different  offset gears for motor pods of different offset?
      #1737
      Avatar photoporsche917
        Toyota Man,
        The grey Slot It motor pods are all the off set ones.  The light grey pods are 1mm offset and require a special white crown gear that do not have any gear markings on them.  The dark grey offset pods are .5mm offset and can be used with a regular colored crown gear.
        The best thing to do with the white crown gears is to count them and write a number on them so you only have to do it once.
          Thanks, marty. I’m learning..
