Home › Forums › Club Races › Racing Calendar, Classes & Regulations › Carrera Modern GT DISCUSSION
- This topic has 27 replies, 7 voices, and was last updated 7 years, 4 months ago by
porsche917.
February 19, 2018 at 10:46 AM #11872
FROM ARY’S INITIAL PROPOSAL RULES NOT PUBLISHED YET – FINAL QUARTER RACING CLASS
“Factory stock” Carrera GT Class: WEC /IMSA – year range TBD but definitely no cars prior to 2013. I will be sharing more details during the club meeting.</p>
Analog models without magnet + stock everything (wheels, motor, gears, etc).– CG Slotcars Carrera guide adapter + Slot.it wood guide.– NSR 5230 Supergrip (20.5 x11) rear tires + Stock front tires.– Polarity switch can be removed and wiring replaced.– Chassis sanding is allowed for float but gap should not be larger than the thickness of a credit card.
— Aston Martin Vantage V12
— Audi R8 LMS<
— BMW M6 GTLM
<br — Chevrolet Corvette CR7
— Ferrari 458
<— Ferrari 488
>— Ford GT RC
— Lamborguini Huracan
Are you crazy? Stock gearing, plastic wheels??>Ok, as far as the plastic wheels go — yeah, we need to give it a try. I have checked the wheels of 10 or so Carrera cars I have purchased in the past 4 to 5 years and found all to be round and centered.>Now, instead of changing the car gearing, each racer will be able to change the voltage of their lanes. We would still be limited to the power supply range (6 to 16 volts) but that is plenty to allow all cars, regardless of weight, to reach their maximum potential.</p>
>Car list may be changed.</p>May 7, 2018 at 3:08 PM #12204Guide adapters are available in USA from:
https://www.slotcarcorner.com/1-32-Slot-Car-Parts-by-Type-/Guides-Braid-and-Wire/Carrera-Guide-Adapter-Standard-p2079.html
http://cloverleafracing.com/product_info.php?products_id=3922"... get on your bad motor scooter and ride!"
Sammy with MontroseMay 10, 2018 at 4:41 PM #12233DIBS – Lucas Stable
001 – Carrera-27559 BMW M6 GT3 -Team RLL, No.25- USA // renumbered as #21
002 – Carrera-27533 Analog 1/32 RTR Ford GT #68 // renumbered as #21"... get on your bad motor scooter and ride!"
Sammy with MontroseMay 20, 2018 at 2:03 PM #12278Notes on the CG Guide Adapters: The ‘Standard’ size fits the BMW and Ford-GT. The large size can fit if sanded down. I recommend sanding down the adapter, not enlarging the chassis hole, (b/c a replacement adapter is easier to get than a new chassis). Reference Ary’s video.
Warning: It does Not take very much sanding to make the large adapter fit. Be sure it slides in easy, without warping from forcing it. Also: These are 3D printed items and the track facing part of the adapter has a rough finish that needs careful sanding to smooth it.Removing Rear Magnet: The magnet behind the motor is held in with a U-shaped clip. Try and pry it out with a small flat-blade screwdriver. If it sticks, you can very very very carefully pop out it out from the bottom of the chassis by placing the screwdriver on one side of the exposed part of the magnet and popping it with your palm. Carefully!
Sammy with MontroseJuly 23, 2018 at 12:37 PM #12843Ary – in the BMW M6 GTLM, the chassis wells for the front body screws bulge into the wheel well, these may interfere with Slot.It wheels – when trying to fit them into the wheel-well so the tire is not visible outside the fenders/wells.
Can we flatten the round part of the screw-well that protrudes into the wheel-well? It’s basically a minor filing operation with a emory board (no major loss of chassis material and hence weight)."... get on your bad motor scooter and ride!"
Sammy with MontroseJuly 23, 2018 at 12:40 PM #12844As of Saturday July 21st, Steve is the series manager for the Q4 Carrera GT series. Congrats, Steve!!
July 24, 2018 at 11:18 AM #12845Interesting. Steve doesn’t look Brazilian. Good luck to him. Looking forward to it.
August 31, 2018 at 5:02 AM #12965Steve, I am not sure about what would be the best way to describe it in the rules but need to add that we allowed the removal of the “cup” portion of the mounting posts.
August 31, 2018 at 10:21 AM #12967Pictures.
August 31, 2018 at 10:20 PM #12972Hey all – planning on joining the group for this series – looking over the cars that are allowed, I’m planning on picking up this version of the Ford GT (Carrera 1/32 Evolution Ford GT Race Car #67) and then being brutally trounced my first few races. 🙂 If there’s any reason this won’t meet the requirements, I’d appreciate a note. Hope to make it out to the Rally event to meet some of y’all.
—Erik (Stabn’Steer)
--Stabn'Steer
September 4, 2018 at 10:11 AM #12979Erik,
First off, welcome!! Yes, the Ford GT is an allowed model to run in the series. Bring it by on a Saturday and we can answer any questions you have about the series.
Look forward to meeting you.
September 7, 2018 at 12:05 AM #12988Question from the newbie.
the rules say regarding rear wheels/tires
– Rear Wheels: Stock Carrera or Slot.it’s (or similar) ‘17.3 x 9.75 mm’ short hub alternatives.I am having a devil of a time finding 17.3×9.75 in stock anywhere. I have found a 17×9.75 (and easily found 17×10). Does the “OR SIMILAR” item in the rules allow for slight differences as long as the wheel has a 15mm hub and the tire measures 20mm diameter in tech?
--Stabn'Steer
September 7, 2018 at 9:50 AM #12990The common wheel to use is the Slot It 17×10 in either aluminum or magnesium. You can use a Slot It F30 tire in 20×10 or a BRM shore 25 in the 20×11 size. Either of these tires will work. The Slot It tires are far more consistent and provide good grip. The BRM tires are a little wider but do not always perform well. I will have all of these items at the track this Saturday if you are planning on being there. I can also show you some other tips for better performance.
September 9, 2018 at 3:05 PM #12999So upon reading the rules and then reviewing the current setups of the members at the club who had cars there. John has CB wheels Randy has Scaleauto wheels and Mark has CB design wheels. All of them are “similar”. I have decided to change the rule to be simply 17×10 mm max. I hope this does not ruffle any feathers.
September 13, 2018 at 1:26 PM #13016Reason prevails!
Are Ninco N80754 PRORACE EVO 3 Wheels 17.4 x 10.2mm hubless with realistic spokes allowed?"... get on your bad motor scooter and ride!"
