Home › Forums › Slot Car Talk › 1/32 Scale Slot Cars › Pit Boxes
- This topic has 26 replies, 4 voices, and was last updated 15 years, 5 months ago by
Race Control.
August 18, 2010 at 3:56 PM #61
What does everyone use for a pit box and what tools, parts, lubes, etc. does everyone keep in them?
August 19, 2010 at 3:59 PM #800Independent of which track I’m going to: small screwdrivers, pliers, micro files, sand paper, x-acto knifes, tweezers, pinion puller, pinion press, caliper, micro scale, iron brush, cotton swabs, lighter fluid. Spare everything; tires, gears, pinions, motors, pickup guides, axles, braid …..
Depending on the track I’m going: soldering iron, variable power supply, tire truer, comm lathe.
I normally have all the tools I use for slot separate from my other tools and I keep the slot ones on the pit box.
August 22, 2010 at 10:19 AM #801Ary,
Do you know what the inside dimensions are for the pull out drawers in the box you showed us yesterday?
August 22, 2010 at 12:46 PM #802I still need to come up with the dimensions. Let me know the best size for the drawers, I guess you want to have the plato boxes inside them .. right?
Another thing, the dimensions I have for the car shelves are 6.7/8″ X 3.3/4″, let me know if they work with your 1/24 cars.Here are the boxes I will be using as a model:
[attachment=3]Box-4b.jpg[/attachment][attachment=2]Box-4a.jpg[/attachment][attachment=1]green-box-2.jpg[/attachment][attachment=0]green-box-1.jpg[/attachment]I am leaning towards the blue box size. I think that the blue box will already be heavy when full … the green one full will probably have 20 pounds more ??
The boxes above can be found here: https://www.northerntouchcarpentry.com/slot_car_boxes.cfm
I have also found plans for a simpler box here: https://www.slotside.com/tt/box1.htmlAugust 22, 2010 at 4:33 PM #803Marty,
I currently have a small tackle box but am leaning to something more like what Ary has posted. I also have a small Carrera 1/32 case to carry my cars. The tackle box has needle nose pliers, wire cutters, wire stripper, Slot.it puller and press, oils, M2 wrench, M2.5 wrench, small screw drivers, gears, pinions, washers, and other misc stuff. It’s currently a disaster and I need a better solution.
-Shawn
August 22, 2010 at 10:43 PM #804Guys,
I e-mailed this guy about his boxes and asked if he would work a discount for four identical boxes. He wants to call me tomorrow to discuss. Let me know your thoughts.
https://slotcarboxes.net/Inventory.html
I was thinking about the Racer Box at the bottom of the page. This guy sells some boxes on Ebay and his basic box can be picked up for $86
I will let you know how the conversation goes.
August 22, 2010 at 11:46 PM #805I have seen those before and decided against it.
August 23, 2010 at 9:30 AM #806Why was that Ary? I’ve seen these in person and they’re really nice and functional.
I’m interested in the Flight Box. I think that’s about the size I want.
August 23, 2010 at 10:12 AM #807I don’t like the design of the JC boxes. The box on ebay for $86 is too small and does not hold enough cars, the second option is basically the same box on ebay with an added shelf in the bottom.
I like the boxes by NTC, the attention to detail seems to be higher. If you don’t consider a possible discount by JC, the racer box is $10 higher than the biggest box NTC makes – The Full Monte – Autumn Hills Edition. Knowing what I normally carry around, the extra drawers and the toll box lid will fit my needs a lot better.I still want to talk to my wood guy this week and see how much he would charge to build me one. I will let you guys know.
August 23, 2010 at 11:00 AM #808Do you have a link to the NTC boxes?
August 23, 2010 at 11:11 AM #809Autorama wrote:The boxes above can be found here: https://www.northerntouchcarpentry.com/slot_car_boxes.cfm
August 23, 2010 at 11:53 AM #810Thanks, Ary. I’ve seen both and must have confused the 2.
August 23, 2010 at 2:37 PM #811I know you said you did not like JC’s designs but he can build anything you want and will give us a 25% discount for an order of four boxes. If its a build quality issue than price is not the issue. Let me know what your thinking.
August 23, 2010 at 2:58 PM #812Quality wise I can’t judge since I have not seen any of the boxes close enough. The reason I like the NTC boxes is because you can carry 12 cars, you have drawers in the hole center section and the tilt-up lid; that’s the attention to detail I was referring to and those are the things I’m looking for on a box. Now I don’t know if we would piss-off JC by asking him to make a NTC box ❓
I will send a message to NTC asking if we could also get a discount when buying 4 boxes … let’s see what happens.August 23, 2010 at 3:00 PM #813There is also this guy: https://www.whiteysslotcarboxes.com/services.html, his boxes seem to be very nice, but I’m not confortable with the price 😕 .
