Home › Forums › Club Races › Racing Calendar, Classes & Regulations › 2021–NSR GT3 (Q2-2021)
- This topic has 48 replies, 5 voices, and was last updated 4 years, 8 months ago by
March 8, 2021 at 1:04 PM #16176
SETUP NOTES: After 20 minutes of painstakingly adjusting my axle/tire height, when thumbing my front tires with the car on its back, I discovered them rubbing the oddly shaped light buckets. Carefully grinding down all the various bumps from the bucket will be Permitted to resolve the contact; as well as adding a thin washer to the body post; or other innovative ideas. NO, truing the tires some more did not completely remove the contact; and I am running the stock size NSR-ZeroGrips. Note: I did Not have this contact issue with my C6R in 2016.
WEIGHT TUNING NOTES: My C7R Wheelbase is 85mm (axle to axle). Centerline is 42.5mm, appx 2mm forward of the Drop-Arm pivot (The Centerline is placed over the middle of the gap between the scales)
My C7R Vette weighs 75gm; the textbook weight distribution is between:
Front 40% / 30gm Rear: 60% / 45gm
Front 45% / 33.75gm Rear: 55% / 41.25gmAs stock, my car’s distribution was:
Front 36% / 27gm Rear: 64% / 48gmAdding 5gm to the nose of the pod[1]: car=80gm
Front 40% / 32gm Rear: 60% / 48gmNOTES: Each model will have different centerlines; each car will have unique weights. Depending on the location the weight is added, will affect the front/rear balance[1]; weights on the Pan “wings” may be easier to tune than a single weight on the motor pod.
Sammy with MontroseMarch 8, 2021 at 4:54 PM #16177I will be running the Audi R8 that I used in the clubs Modern GT series back in 2016. The car has some miles on it but should be up for the test against the large field of Corvettes. Here are the images of the car new and one of the crash that took out the rear wing and caused some additional body damage.
March 8, 2021 at 7:12 PM #16200Tough luck Marty! Who is coming up on you, Ary or Shawn?
Nice looking car, but that pan looks so aerodynamic I need to check the rules on it …"... get on your bad motor scooter and ride!"
Sammy with MontroseMarch 15, 2021 at 1:37 PM #16225NEED RSVP – ‘register’ for NSR-GT3 race.
We need to balance out all the good-ole-boyz Vetts with some:
ASVs(AMs), R8s (OoOoO), Z4s (Bimmer), Mercs, 997s (goenfausten)"... get on your bad motor scooter and ride!"
Sammy with MontroseMarch 26, 2021 at 11:55 AM #16238I need to get caught up on my reading of our expectations…I THINK we’re allowing masked men to show up at the events. With many of us getting the vaccine or on the list, and since I’ve been able to successfully avoid getting the ‘vid with how I am managing my interactions, I’d be comfy jumping back into in-person action.
I don’t have a car yet, but I plan on getting caught up a bit over the weekend on our messages and will likely make a purchase since I love GT3 cars. I may not make the 10th as that is planned to be my first kart race down in New Braunfels, but if it rains, we don’t race due to the extra slippery nature of the concrete there…it becomes a true skating rink, even with rain tires so for safety’s sake they tend to cancel. In that event, I’d love to be slotting.
--Stabn'Steer
March 27, 2021 at 3:17 PM #16259So based on the notes from last weekend’s meeting, this GT3 event will be a “driver present” event and not proxy. I do want to verify that before I pull the plug on a car. I plan on running the BMW Z4 Presentation Livery, but only if I can drive it. Sorry – but proxies just don’t excite me. The livery comes as a #1, but I can change that if the Audi’s already existing #1 is a hiccup to the plan.
--Stabn'Steer
March 29, 2021 at 9:52 AM #16260Erik
I plan on driving my own car and I believe Randy does as well. Presumably if someone else wants to enter the race but is yet reluctant to race at HQ, one of the members that does attend could race his car as a proxy driver. We should, therefore be able to run the race as a regular owner/driver series.
March 29, 2021 at 1:46 PM #16262SM COMMENTS:
ERIK (and others)
1 Re BMW-#1 Z4, if you are planning on the White Presentation livery- that should be NP.
2 If you can attend, great – yes show up masked and enter the fray.
3 If you cant (b/c of the kart race) – you can either drop that Round (the normal process) or leave your car and ask someone to be your Driver for round-1.
4 In general, anyone wanting to field a car but not able to attend (regardless if due to Covid, health, travel issues); they can hire another member as their driver.(I am considering hiring John to build my car and Steven to drive – based on recent GP-C history LOL. I will deal with sponsors, organizing the VIP Tent and post race parties etc.)
Seriously – if you want to enter a car but cannot attend in person, reach out to another member … let’s keep this simple and ‘easy’
Sammy with MontroseMarch 29, 2021 at 2:05 PM #16263TUNING NOTES
MOTOR – At the series voltage of 11v, some people testing Vettes are experiencing the 25k motor to be “too-hot” (jackrabbit hops and fishtails); even with Low gearing (e.g. the OEM 32/11 = 2.91 ratio, or 33/11 = 3.0).
Conversely, the 22k or 21.5k motors may need Higher gearing (2.82, 2.73) to go below 4.3s.BALANCE – the nose on the Vettes are light, so some weight behind the guide (~3 to 4gm) or on the nose of the motor-pod (~ 5-7gm) may be something to experiment with.
Sammy with MontroseApril 4, 2021 at 12:03 AM #16277Due to availability of parts and prices, I will be changing to the BMW Z4 Gulf Livery #52.
--Stabn'Steer
April 4, 2021 at 7:57 PM #16278Hey – I hate to drop this on you guys but here’s some calcs that defy the recent idea of using the 22k/21.5k motors (at 11v). Since we are using S/W gears our options are limited.
Also – I did the numbers using 12v and 11v and not surprisingly, 11v favors the 25k motor and 12v favors the 22k/21,5 motor.11 VOLTS
25,000 motor rated, * 11/12v = 22,800 effective
Rear wheel RPM Ratio Spur/pinion
8085 2.82 31/11
8056 2.83 34/12
7835 2.91 32/11 OEM/Stock22/21.5 rated, avg of 21,750 * 11/12v = 19,938 effective
8100 2.46 32/13
7975 2.50 30/12
7728 2.58 31/1212 VOLTS
25,000 motor rated
8091 3.09 34/1122/21.5 rated, avg of 21,750
8146 2.67 32/12
7967 2.73 30/11
7713 2.82 31/11So – at this point I am thinking we should stick with 11 volts since if most people have stuck with the stock motor there are less gear combinations they have to experiment with.
IDEAS?
Sammy with MontroseApril 5, 2021 at 10:38 AM #16280I fully planned to race my Corvette in person, but my grandson is pitching his last high school season and the game this week is Saturday. I will leave my car at the club and you can decide to run it or not in the race.
April 5, 2021 at 12:13 PM #16281TA – of course we will race it : )
We will put it into rotation and select one or even perhaps 3 people (proxy style) to drive it.
I will be closely checking your Reifen to ensure they are legal – no experimental BFG compounds are allowed … no gluing NSR over the original sidewall names etc."... get on your bad motor scooter and ride!"
Sammy with MontroseApril 5, 2021 at 10:04 PM #16282I don’t have a lot of experience or parts for NSR. My Corvette came with the 25K motor. I tried it for the first time today with a 33-tooth spur; it was undrivable. Even with weight it was very twitchy, especially under braking at the ends of the long straights. I ordered 34- and 35-tooth gears today. I still plan on running with the 25K motor, hoping that the higher numerical gearing will be enough to calm it down. I am ordering a 36-tooth gear as well.
April 6, 2021 at 5:57 PM #16283RUSS – yes I too spent several hours this Sat & Sun trying to either a) break 4.1 or b) have a car that did not jack-rabbit in the straights or fishtail in the corners. The Supergrips marbled a little and contributed to both the jumps and slides.
After too many 4.4s, I switched back from the 22k motor to the 25k OEM motor; and went back and forth from the 32z (OEM) to 31z spurs. With the 32z I could barely break high 4.3s; with the 31z I clocked a few mid and high 4.2s but mainly stayed in the 4.3s My pinion is a 11z (OEM spec).
I also experienced more rubbing on the front tires (I need to double-check to see if I am running the 17mm or 19mm NSR-No-Grips)
