New Scaleauto SC-8003 chassis
Home Forums Slot Car Talk 1/24 Scale Slot Cars New Scaleauto SC-8003 chassis
Viewing 6 posts - 1 through 6 (of 6 total)
  • #12046
      I just wanted to let everyone know that the new Scaleauto SC-8003 GT3 chassis uses Torx nuts and not hex.  It appears that it’s using a mix of T5 and T6 nuts.  I’m getting a Wiha Torx driver set tonight to get everything apart so I can be aware of every bolt on the car.
      I’ll keep this up to date on changes and things I find.
      #12055
        So I got into the car late last night.  The carbon fiber mounting plate is thicker than the metal plate on the older cars, so it has less float.  I’m not sure what that’s going to mean on the track right now so I’m not suggesting it’s either good or bad.  I spent a good amount of time trying to straighten the body on the chassis as the Z4 I got was crooked and offset.  Everything else looks to be the same so I’ll get to the track and true the stock tires and see how it runs.
        #12302
        Avatar photoRadial TA
        Participant
          Where did you find the Wiha torx wrenches?
          #12303
          Avatar photoporsche917
            You can get the Wera versions from Alan at 132slotcar.
            Wera 118040 TX 5 x 40mm s/driver for TORX
            Wera 118042 TX 6 x 40mm s/driver for TORX
            #12305
              Randy,
              I posted this in the Tips and Tricks section about a month ago:
              http://austinslotcarclub.com/forums/topic/wiha-tools-locally/
              #12322
              Avatar photoBarkingSpyder
              Participant
                TIRE WARNING – see the *main ScaleAuto GT thread  http://austinslotcarclub.com/forums/topic/q3-scaleauto-series-discussion/page/2/#post-12326
