2025 NSR F22 – Road Track
Bellator Bellator 2 years ago
** Previous Rules - Subject to Revision **
  • NSR Formula 22
  • Stock helmets or Interlagos 1/32 helmets from Electric Dreams.
  • Mandatory: Body must start every race with all major parts intact including wings.  Permitted – Antennas, mirrors, other small parts Not-required to be replaced after crash damage
  • Mandatory: White Kits must be painted, and unique with colors, decals, numbers Undecorated models in colors must have at least 3 legible numbers. Custom liveries allowed
  • Open-Choice: Body screws (NSR OEM or smooth shank Slot.it, NSR, or Slotting Plus)
  • PROHIBITED: Lexan bodies or cockpits.
  • Open-Choice: NSR branded Formula 22 chassis – any hardness
  • Permitted: Chassis may be sanded only enough to facilitate float. Series Manager may disqualify (DQ) car if excessive material is removed.
  • Mandatory: NSR brand guides  Options: Wood Depth/Screw Post #4859; OEM Snap-In #4841; Long Keel Screw Post #4845, Long Keel Snap-In #4843
  • Open-Choice: Motor wires and pick-up braids
  • Permitted: Ballast (must be above the chassis pan; inside the body)
  • PROHIBITED: Magnets.  (Magnet must be removed from stock chassis).
  • Magnetic downforce may not exceed 30 grams as measured on the Magnet Marshal.
Motor & Pod
  • Mandatory: NSR OEM Motor King-21 EVO-3; #3023   21.4k Rpm 350gm-Torque
  • Mandatory: NSR OEM #1288 Extra-Hard Red Inline-configuration
  • Permitted and Encouraged: M2 Motor retaining screws (flat-head or grub); or gluing motor to pod
  • PROHIBITED: Motor pod protruding below chassis more than 0.25mm, Suspension springs.
Gears - UPDATED 10-31-24
  • NSR Inline Crowns: NSR # 6324, 6325 or OEM #3227
  • Optional: Slot.it Inline Crowns* : 27zGI27Bz (black) 25zGI25Bz (orange) 24z GI24Bz (green) *Subject to further testing & approval.
  • RECOMMENDED: Brass/bronze vs. Alloy/aluminum (brass seems to be more durable
  • Permitted: NSR #6327 Formula 22 OEM 10 tooth pinion only.  NSR #4105 pinion puller is needed for adjustment or removal. The club will have one of these tools for everyone to use.
  • Given the recent issues with the NSR crown gears, the newer NSR (Slot.it looking) crowns will be allowed.  The Slot.it modular crowns are also allowed.
  • The Pinion must be the stock NSR 10 tooth.
Wheels & Axles
  • Front Wheels-Permitted: NSR OEM # 5030 only.
  • Rear Wheels-Permitted: NSR OEM #5031 16.5x10 or NSR #5033 16.5x12 Spanish
  • Permitted:   Foam Donuts, or O-rings to fill Air-System Rib Gap
  • Mandatory: NSR OEM Formula 22 wheel inserts.   May be painted
  • Mandatory: NSR OEM #4892 Solid axles for front and rear
  • Open Choice: Stop collars, spacers, and washers
  • Mandatory: OEM NSR brass bushings
  • Permitted - Gluing brass bushings to the pod
  • MAXIMUM TIRE WIDTH: 68mm for Front Wheels and 65mm for Rear Wheels
  • Front Tires-Permitted: NSR No-Friction OEM (NSR #5296N 19x19.5)
  • Rear Tires-Permitted: NSR Super OEM #5294S 19x13 or NSR #5295 19.5 x13 in Super, Ultra or Extreme compounds.
  • Permitted and Encouraged: gluing, truing, and camfering/rounding of the tires edges.
  • PROHIBITED: Traction compounds and glazing the front tires with nail polish or Super-Glue/CA.
Track Power
  • 12 Volts
Any part not mentioned must be a NSR Formula 22 stock part as provided with the car. Contact Series managers (John or Marc) with ANY questions on the rules. Post questions and suggestions to the Forum NOT via emails.  All rules may be amended by testing and are subject to final approval by managers at end of Q2.
7 Reply
Last year I had a lot of trouble getting my magnetic downforce within spec. Does anyone know if rotating the motor 180 degrees might make a difference?
I tried that, but it did not make a difference.  I think we need to look at this series like we did the Thunderslot series - as long as there are no visible signs of someone trying to increase the downforce of the motor, the car should be allowed to run as is unless the downforce is drastically outside of the mean.  For my car to be at 132grams of downforce and not be allowed to run even though it was completely stock is absolutely ridiculous.  True, you can reduce the diameter of the rear tires to increase the downforce but we can police that by looking at the ground clearance of the car.
in reply to porsche917
Agree. Let’s fix the minimum ride height and go from there.  This needs to be simple.
After a robust discussion and more than a few test measurements of last year's cars during the club's meeting on Saturday, September 13 the decision was taken to take the first race-day downforce inspection results and, based on the variability, determine any future adjustments to the rules.
It is worth noting that the chassis rubbing on the track is still prohibited, so racers are encouraged to keep that in mind with their builds.
Also worth noting is that a second decision was taken to reintroduce the 'B' class with this race.  The 'B' class will be run at 10 volts.  Roster to follow.
in reply to Bellator
Last I heard class b might be running separate heats at a lower voltage. That means a different setup somehow in Race Coordinator I guess adding two races ASCC 2025 NSR F22A, and ASCC 2025 NSR F22B?
