Series Manager: Mel
Assistant Series Manager: Marty
Slot.It Group C Models Allowed
- Jaguar XJR6, XJR9, XJR10, XJR11, XJR12
- Lancia LC2/84, LC2/85
- Mazda 787B
- Nissan R89C, R90V, R91VP
- Porsche 956, 962, 962 IMSA
- Sauber C9 Mercedes
- Toyota 86C, 88C, JTK 63C
- The body cannot be modified in any way.
- The stock plastic cockpits and glass are mandatory
- Lexan cockpits or glass are prohibited.
- Body must start every heat with radiators, windows, and wings in their correct location. If any of these items fall off during a heat they must be repaired before the next heat starts.
- Antennas, mirrors, wipers, and tow hooks are not required and do not have to be replaced if they come off.
- White kits are allowed but must be painted, or uniquely decaled with at least one coat of paint. At least two numbers must be visible.
- Body screws open choice. These can be taped to prevent loss. Any car that loses a screw and causes an issue with a competitor’s car will have a 5 lap penalty applied.
- No modifications to the chassis are allowed.
- Chassis must be Slot.It or Policar that is intended for the body.
- Motor pod cut-outs can be removed.
- Flashing on the chassis may be removed to allow better floating of the body. The gap between the chassis and the body cannot be greater than the thickness of a credit card.
- Front axle lower adjustment caps are optional.
- Modification to the upper axle loops is prohibited.
- Front axle height adjusting grub screws are open choice.
- Magnets of any type are prohibited.
- Ballast is allowed but must be above the chassis pan. A 5-lap penalty will be imposed if ballast falls onto the track and causes an issue with a competitor’s car.
Guide
- Slot.it guides are mandatory. The Slot.it SICH-07 deep wood screw guide highly recommended.
- Pick-up braids are open choice.
- Guide spacers are open choice
Set Up
- Wheel/tire must not be visible outside wheel-well/fender when viewed from above.
- The static weight of the car cannot exceed 120 grams.
- Magnetic downforce cannot exceed 30 grams.
- Slot.it V12/4 23K motors are mandatory. The older version of this motor has a dark orange end while the newer motors have a white end.
- The small circuit board on top of the motor can be removed.
- Any modifications to the motor are strictly prohibited.
- Lead wires and lead wire guide terminals are open choice.
Motor Pod
- Slot.it in-line motor orientation is mandatory.
- The motor pod is prohibited from protruding below the chassis.
- Flashing may be removed from the motor pod to allow better float. Excessive removal of material determined by the scrutineer.
- Motor can be held in place with screws. Screws are open choice.
- Motors cannot be held in with tape or glue.
- Slot.it stop/axle collars are allowed.
- Spacers/washers are open choice.
- Slot.it CH14 or CH56b spherical bushings are mandatory.
- Pod screws are open choice.
- Tape may be used to prevent the pod screws from falling out.
- Tape over the motor pod to limit pod movement is not allowed.
- Slot.it suspension kits are not allowed.
- Slot.it in-line crown gears and pinions are mandatory.
- All versions of Slot.it’s in-line crowns are allowed.
- Gear ratio is open.
- Modifications to crown gears or pinions are prohibited.
Wheels
- Slot.it wheels are mandatory.
- Rear wheels –
- Diameter - 15.8mm or 16.5mm
- Width – 8.2mm or 10.2mm
- Material – Aluminum or magnesium
- Front wheels – only 15.8mm wheels are allowed.
- Diameter – Only 15.8mm
- Width – Only 8.2mm
- Material - Plastic, aluminum, or magnesium
- Rear wheels –
- Slot.it wheel inserts are mandatory
- Any Slot.it Group C wheel inserts may be used.
- Any modifications to the wheels are prohibited.
Axles
- Only Slot.it axles are allowed.
- Any modifications to axles are prohibited.
- Slot.it independent front axle kit is allowed.
- Axle spacers and axle stops are allowed.
- Front tires must be Slot.it tires.
- Front tires must be 10mm wide.
- Rear tires can be any 10mm width Slot.it tire or any 10mm width NSR Supergrip or Ultragrip tire.
- Rear tires cannot be wider than 11mm measured at the widest part of the tire.
- Tires may be glued to the wheels, trued, and have their edges rounded.
- Traction compounds are prohibited.
- Varnishing the front tires to make them slick is not allowed.
- Zero-Grip (front) tires are highly recommended.
Track Power: 12 volts for A group, 10 volts for B group
If it is not mentioned, it is not legal. These rules were written to create a fair event and not for racers to look for loopholes.
