2026 Q1 - Slot.it Group C - Road Track
Bellator Bellator 12 months ago
Series Manager: Mel
Assistant Series Manager: Marty
Slot.It Group C Models Allowed
  • Jaguar XJR6, XJR9, XJR10, XJR11, XJR12
  • Lancia LC2/84, LC2/85
  • Mazda 787B
  • Nissan R89C, R90V, R91VP
  • Porsche 956, 962, 962 IMSA
  • Sauber C9 Mercedes
  • Toyota 86C, 88C, JTK 63C
  • The body cannot be modified in any way.
  • The stock plastic cockpits and glass are mandatory
  • Lexan cockpits or glass are prohibited.
  • Body must start every heat with radiators, windows, and wings in their correct location.  If any of these items fall off during a heat they must be repaired before the next heat starts.
  • Antennas, mirrors, wipers, and tow hooks are not required and do not have to be replaced if they come off.
  • White kits are allowed but must be painted, or uniquely decaled with at least one coat of paint.  At least two numbers must be visible.
  • Body screws open choice.  These can be taped to prevent loss. Any car that loses a screw and causes an issue with a competitor’s car will have a 5 lap penalty applied.
  • No modifications to the chassis are allowed.
  • Chassis must be Slot.It or Policar that is intended for the body.
  • Motor pod cut-outs can be removed.
  • Flashing on the chassis may be removed to allow better floating of the body.  The gap between the chassis and the body cannot be greater than the thickness of a credit card.
  • Front axle lower adjustment caps are optional.
  • Modification to the upper axle loops is prohibited.
  • Front axle height adjusting grub screws are open choice.
  • Magnets of any type are prohibited.
  • Ballast is allowed but must be above the chassis pan. A 5-lap penalty will be imposed if ballast falls onto the track and causes an issue with a competitor’s car.
Guide
  • Slot.it guides are mandatory.  The Slot.it SICH-07 deep wood screw guide highly recommended.
  • Pick-up braids are open choice.
  • Guide spacers are open choice
Set Up
  • Wheel/tire must not be visible outside wheel-well/fender when viewed from above.
  • The static weight of the car cannot exceed 120 grams.
  • Magnetic downforce cannot exceed 30 grams.
  • Slot.it V12/4 23K motors are mandatory.  The older version of this motor has a dark orange end while the newer motors have a white end.
  • The small circuit board on top of the motor can be removed.
  • Any modifications to the motor are strictly prohibited.
  • Lead wires and lead wire guide terminals are open choice.
 Motor Pod
  • Slot.it in-line motor orientation is mandatory.
  • The motor pod is prohibited from protruding below the chassis.
  • Flashing may be removed from the motor pod to allow better float. Excessive removal of material determined by the scrutineer.
  • Motor can be held in place with screws.  Screws are open choice.
  • Motors cannot be held in with tape or glue.
  • Slot.it stop/axle collars are allowed.
  • Spacers/washers are open choice.
  • Slot.it CH14 or CH56b spherical bushings are mandatory.
  • Pod screws are open choice.
  • Tape may be used to prevent the pod screws from falling out.
  • Tape over the motor pod to limit pod movement is not allowed.
  • Slot.it suspension kits are not allowed.
  • Slot.it in-line crown gears and pinions are mandatory.
  • All versions of Slot.it’s in-line crowns are allowed.
  • Gear ratio is open.
  • Modifications to crown gears or pinions are prohibited.
Wheels
  • Slot.it wheels are mandatory.
    • Rear wheels –
      • Diameter - 15.8mm or 16.5mm
      • Width – 8.2mm or 10.2mm
      • Material – Aluminum or magnesium
    • Front wheels – only 15.8mm wheels are allowed.
      • Diameter – Only 15.8mm
      • Width – Only 8.2mm
      • Material - Plastic, aluminum, or magnesium
  • Slot.it wheel inserts are mandatory
  • Any Slot.it Group C wheel inserts may be used.
  • Any modifications to the wheels are prohibited.
Axles
  • Only Slot.it axles are allowed.
  • Any modifications to axles are prohibited.
  • Slot.it independent front axle kit is allowed.
  • Axle spacers and axle stops are allowed.
  • Front tires must be Slot.it tires.
  • Front tires must be 10mm wide.
  • Rear tires can be any 10mm width Slot.it tire or any 10mm width NSR Supergrip or Ultragrip tire.
  • Rear tires cannot be wider than 11mm measured at the widest part of the tire.
  • Tires may be glued to the wheels, trued, and have their edges rounded.
  • Traction compounds are prohibited.
  • Varnishing the front tires to make them slick is not allowed.
  • Zero-Grip (front) tires are highly recommended.
Track Power:    12 volts for A group, 10 volts for B group
If it is not mentioned, it is not legal.  These rules were written to create a fair event and not for racers to look for loopholes.
