1/32 Scale Slot Car Standards
Race Control Race Control 15 years ago
Calling All Drivers,
I found a set of 1/32 scale car standards as authored by the Classic Slot Car Racing Association of the UK.
I would suggest we use these standards as guidelines for establishing our new racing classes.
Any thoughts or feedback?
Thanks,
Jim J.
I like the definitions of the classes and the rules are generally pretty simple.
A couple of things:
  1. I think we still want to limit the RPM of the motor. For example: Say you're building a narrow chassis car that takes a FF-050 motor. There are FF-050 motors available that range from 10k to 39k RPM. To keep speeds closer to a scale representation and field more even on available power we probably want to limit that to 14k.
  2. Just to be clear: we will run RTR and Scratch built together. Not as separate classes.
BTW: That timeline document is pretty interesting.
Interesting to see that they allow any type of motor for all classes.
I think we could use some of the Sport Cars class 3 standards on our Mille Miglia class:
• Motor orientation: Inline only.
• Front wheels and tyres: Minimum diameter 19mm, minimum width 5mm.
• Rear wheels and tyres: Minimum diameter 21mm, maximum width 7.5mm.
• Minimum ground clearance 2mm.
• Maximum overall width: 57mm.
Sports Cars class 5 standards could be used on the Classic GT series:
• Motor orientation: free.
• Front wheels and tyres: Minimum diameter 16mm, minimum width 6mm.
• Rear wheels and tyres: Minimum diameter 19mm, maximum width 12mm.
• Minimum ground clearance 1.5mm.
• Maximum overall width: 64mm.
Now, they are classifying GT cars as: "A closed, hard top car with 2 or 2+2 seats and bodywork covering the wheels. Cars in this class would normally be based on road going, hard top, 2 or 2+2 seat production cars.". Are we only allowing closed cars for our Classic GT Series?
