1/32 Scale Slot Car Standards
Race Control Race Control 15 years ago
Calling All Drivers,
I found a set of 1/32 scale car standards as authored by the Classic Slot Car Racing Association of the UK.
I would suggest we use these standards as guidelines for establishing our new racing classes.
Any thoughts or feedback?
Thanks,
Jim J.
Interesting to see that they allow any type of motor for all classes.
I think we could use some of the Sport Cars class 3 standards on our Mille Miglia class:
• Motor orientation: Inline only.
• Front wheels and tyres: Minimum diameter 19mm, minimum width 5mm.
• Rear wheels and tyres: Minimum diameter 21mm, maximum width 7.5mm.
• Minimum ground clearance 2mm.
• Maximum overall width: 57mm.
Sports Cars class 5 standards could be used on the Classic GT series:
• Motor orientation: free.
• Front wheels and tyres: Minimum diameter 16mm, minimum width 6mm.
• Rear wheels and tyres: Minimum diameter 19mm, maximum width 12mm.
• Minimum ground clearance 1.5mm.
• Maximum overall width: 64mm.
Now, they are classifying GT cars as: "A closed, hard top car with 2 or 2+2 seats and bodywork covering the wheels. Cars in this class would normally be based on road going, hard top, 2 or 2+2 seat production cars.". Are we only allowing closed cars for our Classic GT Series?
I like the definitions of the classes and the rules are generally pretty simple.
A couple of things:
  1. I think we still want to limit the RPM of the motor. For example: Say you're building a narrow chassis car that takes a FF-050 motor. There are FF-050 motors available that range from 10k to 39k RPM. To keep speeds closer to a scale representation and field more even on available power we probably want to limit that to 14k.
  2. Just to be clear: we will run RTR and Scratch built together. Not as separate classes.
BTW: That timeline document is pretty interesting.
