Slot.IT OffSet Crown Gears are a challenge to keep track of, since they are all a neutral white Nylon color. YES - the tooth count (aka the "Z" number) is located in the valley between teeth and collar, but they are Still Very hard to find and read (need geezer goggles or magnifying glass).
The most prevalent organization method seems to be "pillboxes" with labels for the various sizes.
Marking with a fine-point Sharpie works Ok until you mount the gear, and between the lubes and your fingers, soon the marking fades.
In addition; I have started engraving the Tooth count on the Collar.
Usually, all that is needed is the "ones place" number - since all are in the twenties (23, 24, 27, etc).
A $15 micro-engraver, aka. engraver-pen, are easy to find at Harbor Freight, Joann's Fabric, Hobby Lobby etc.
To bad Slot.IT did not either (a) make the collar black/blue for off-set gears and used the same color scheme as the non-offset crowns; or (b) color-coded the Collars/shanks (leaving gears natural nylon)
(c) put the Tooth number (in a larger font) on the larger non-toothed back side of the crown.
