1/24 Motor Specifications:
Group 16D: 70 turns of 30 Gauge wire
.513 diameter, minimum stack .600
Group S-16D: 60 turns of 28 Gauge wire
.513 diameter, minimum stack .490
Group 12: 50 turns of 29 gauge wire
.510 to .518 diameter, minimum stack .350
Group 20: 38 turns of 27 gauge wire
.510 to .518 diameter, minimum stack is to be a minimum of .440
Group 7: range from 15 turns of 24 gauge to 26 turns of 26 gauge wire
.459 to .480 diameter, no minimum stack length
Group Open: Custom Winds (UNLIMITED)
___________________________________________________________________________________
Hybrid Motors Specifications (Used on 1/32 and 1/24 slot racing):
JK Falcon 7, part number JK30207
• 65 turns of 30 AWG wire
• Stack length - .375"
• Arm timing - 15 degrees nominal
• Diameter - .513"
• Magnets - Neodymium
• Internal brushes and springs
• Oilite bushings
TSR D3, part number TD301
• Arm timing - 3 degrees nominal
• Diameter - .513"
• Oilite bushings
Pro Slot Euro Mk1, sealed, with Chinese-made arm, part number PS4002
• 80 turns of 31 AWG wire
• Stack length - .400"
• Diameter - .513"
• Arm timing - 20 degrees nominal
• Magnets - ceramic
• External brushes and springs
• Oilite bushings
Pro Slot Euro Mk1 "Puppy Dog", sealed, with American-made arm, part number PS4002B
• Minimum of 75 turns/Maximum of 80 turns of 31 AWG wire
• Diameter - .513"
• Arm timing - 25 degrees nominal
• Magnets - ceramic
• Oilite bushings
Slick 7 Mini Brute, part number S7-588A
• 82 turns of 31 AWG wire
• Arm timing - 5 degrees nominal
• Diameter - .513"
• Magnets - Ceramic
• Oilite bushings
