2026 Q4 - NSR F1 1986 to 1989 - Road Track
Bellator Bellator 1 year ago
Series Manager: John B.
  • An exciting option for our 2021 series are  accurate 1/32 scale helmets  featuring many 1980s legends and even recent stars!
  • Mandatory: Body must start every race with all major parts intact including wings.  Permitted  - Antennas, mirrors, other small parts Not-required to be replaced after crash damage.
  • Mandatory: White Kits must be painted, and unique with colors, decals, numbers (to claim a Decorated livery, visit this link or email the series manager).
  • Open-Choice: Body screws (NSR OEM or smooth shank Slot.IT or NSR)
  • PROHIBITED: NSR 1522 Lexan  driver/cockpit
  • Open-Choice: NSR branded F1 chassis - any hardness
  • Permitted: Chassis may be sanded only enough to facilitate float. Series Manager may disqualify (DQ) car if excessive material is removed.
  • Mandatory: NSR brand guides   Options: Wood Depth/Screw Post #4859; OEM Snap-In #4841; Long Keel Screw Post #4844; Long Keel Snap-In #4843
  • Open-Choice: Motor wires, Pick-up braids
  • Permitted: Ballast (must be above the pan; inside the body)
  • PROHIBITED: Magnets
Motor & Pod
  • Mandatory: NSR OEM Motor King-21 EVO-3; #3023   21.4k Rpm 350gm-Torque
  • Mandatory: NSR OEM Extra-Hard Red Inline-configuration #1283
  • Permitted and Encouraged: M2 Motor retaining screws (flat-head or grub); or gluing motor to pod
  • PROHIBITED: Motor pod protruding below chassis more than 0.25mm
  • Magnetic downforce may not exceed 40 grams as measured on the Magnet Marshal.
  • Permitted: NSR Inline Crowns OEM 27z #6327 (Black/grey) 25z #6325 (Orange)   24z #6324 (Blue)
  • Permitted: [as of 9/25 vote and SM approval] Slot.IT gears - limited to 27z GI27Bz (black) 25z GI25Bz (orange) 24z GI24Bz (green)
  • RECOMENDED: Brass/bronze vs. Alloy/aluminum (brass seems to shed less)
  • Permitted: NSR Pinions OEM 5.5mm Dia-10z #7010 (Alternates: 10z #6810;  9z #7009  9z #6809, or Equal Slot.IT Pinions (10z, 9z)
  • Open-Choice: Gear Ratios;  Estimated Rear Wheel RPMs: @11v: 27/10= 7,265  25/10 = 7,847  24/10 = 8,174
Wheels & Axles
  • Front Wheels-Permitted: NSR OEM #5020 Alum 13mm x 8mm;  (Alternate #5025 Plastic-CNC Ultra-Lite 13mm x 8mm)
  • Rear Wheels-Permitted: NSR OEM #5021 Air-System-Alum-2-Rib 13mm x 10mm;  (Alternate #5027 Solid-Rib 13mm x 10mm)
  • Permitted: Thunderslot Foam Donuts, or O-rings to fill Air-System Rib Gap
  • Mandatory: NSR wheel inserts #5440, 5441, 5442, 5443
  • Mandatory: NSR Solid axles. Prohibited: Independent rotating front axles
  • Open-Choice: Stop collars, Spacers/washers.
  • Mandatory: OEM NSR brass bushings   Permitted. Gluing to Pod
  • MAXIMUM TIRE WIDTH: 68mm for both Front and Rear Wheels
  • Front Tires-Permitted: NSR No-Friction OEM #5283 18mmx10mm -or- #5291 17mmx10mm; #5290 16mmx8mm
  • Rear Tires-RECOMENDED NSR OEM #5284 Supergip 19.5mmx13mm; (Permitted: any NSR 19.5 x 13 tires)
  • Permitted and Encouraged: Truing; Gluing; Camfering/rounding.
  • PROHIBITED: Traction compounds. Glazing of front tires with Nail Polish or Super-Glue/CA
Track Power
  • Group A: 11 vdc
  • Group B: 10 vdc
Contact Series Manager  (John B. / Lotus Jr) with ANY questions on the rules. Post questions and suggestions to the Forum NOT via emails
13 Reply
Note to racers in the 'A' Group: After testing by several members, the race director has updated the racing voltage from 12v to 11v.
