New Slot.It Orange-bell motor -23k-rpm/170g-tq
BarkingSpyder BarkingSpyder 10 years ago
(from https://www.pendleslotracing.co.uk/slot-it-small-can-motor-23-000-rpm.html)
Slot.It small can motor has 23.000 rpm with 170gcm torque @12v.  This Slot.It V12/4 motor (SIMX16) has been included in Slot.it cars starting May 2016.
The previous motor (SIMX06) was rated at 21,5000rpm. According to Slot.it the MX06 had some versions (ed. unmarked) capable of producing 23,000rpm.  (ed.  these had a redish-orange color bell, and an audibly noticeable higher pitch)
A few years ago the Slot.it factory changed the metal case of the orange endbell motor, from one with rounded edges, to a newer shape with Squared edges. This unintentionally increased the RPM from 21,500rpm to 23,000rpm, but the motor specification was never officially upgraded in the catalogs or website.
The biggest difference for most racers is the endbell, which is now a single piece in order to hold the brushes more firmly and hopefully have a more stable production across batches. As far as performance is concerned, the V12/4 MX16 motor is expected to be similar to the old V12/3 (dark-orange) units rated at 21,5000rpm, but having the 23,000 rpm capability.
Orange End Bell Alternatives:
Piranha #PSM21 21.5krpm 165g-cm @ 12v from SCC -$8; as compared to $16-19 for Slot.ITs
Piranha #PSM25BB 25krpm 185g-cm - $13 *with ball bearings*
NSR SHARK21  #NSR3041  21.9krpm 164g-cm - $12
Thunderslot 'Mach-21'  #THMTMACH21DS 21.5krpm 175g-cm - $22
What's really unfortunate is the part number remains the same - MX16.  I wish they would have changed the part number to reflect the new generation of motor and the white end bell color.  Now if you order a MX16 motor you won't know what you get until you open the box.
2020 SLOT.IT MOTORS - The Slot.IT 2019/20 Catalog shows:
-- 23,000 RPM 'Orange' End-bell motor now has a White end-bell with a 23000 RPM Tattoo on the can.
MX16 V12/4. White 23,000 170g/cm White end bell
-- DTMs apparently come with MX15 V12/4. White 21,000 150g/cm Black end bell
Slot.IT Catalog
