I have found this guide to be a great alternative to Slot.it wood guides. The shaft is longer than most and needs trimming for a custom-fit. It also needs a light sanding to fit into a slot.it guide hole (or an adapter) b/c it is intentionally thicker to provide a snug fit (that get perfect after about an hours track time).
It uses the same grub-screw design as the slot.its. It is ever so slightly deeper than the slot.it wood guide. It also has bumps on each end so that it has the effect of a thicker guide without the additional mass.
https://www.professormotor.com/product-p/pmtr1147.htm
Professor Motor PMTR1147 1/32 Universal DEEP WOOD Guide
